plies
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Writes a ply entity.
Assigns entities to a ply entity.
Assigns lines to a ply entity.
Assigns surfaces to a ply entity.
Assigns a node to a ply entity.
Assigns the second orientation angle to a ply entity.
Assigns a system to a ply entity.
Assigns a type to a ply entity.
The list of deprecated hminlib functions, and the new functions to use.
The list of undocumented hminlib functions.
