HMIN_ply_write_surfacelist()
Assigns surfaces to a ply entity.
void HMIN_ply_write_surfacelist(unsigned int num_entities,HM_entityidtype *entity_ids);
HyperMesh hminlib Function
Assigns surfaces to a ply entity. Must be called after HMIN_ply_write().
num_entities
The number of surfaces to write.
entity_ids
The IDs of the surfaces.
None.
