hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Calculates the range between file locators.
Indicates if the last of a specified entity is read.
Creates storage in memory where you can store a block of file locators.
Frees the memory that was used for file locators.
Determines if an entity is present within the given file.
Provides a way to reposition the file.
Assigns a location for the file locator.
ON THIS PAGE
ON THIS PAGE
