HMIN_filelocator_getfound()
Determines if an entity is present within the given file.
int HMIN_filelocator_getfound(void * filelocatorptr, int filelocator);
HyperMesh hminlib Function
filelocatorptr
The pointer to the block of file locators.
filelocator
The index into the block of file locators.
1, if the entity is found.
0, if the entity is not found.
None.
