HMIN_filelocator_create()
Creates storage in memory where you can store a block of file locators.
void * HMIN_filelocator_create(int numberoffilelocators);
HyperMesh hminlib Function
The number of entities you want to keep track of in the file.
1, if it has not read through to the end of the block.
0, if it has reached the end of the block.
None.
