HM_elementconfiggetnumberofnodes()
For an element configuration, this function returns the number of nodes that the element uses. For rigidlinks and RBE3s, this function returns 0 because these elements have a variable number of nodes.
int HM_elementconfiggetnumberofnodes(int config);
HyperMesh hmlib Function
config
The configuration of the element.
The number of nodes used by the element.
None.
