HM_getmachinesizeofdouble()
Writes information to a binary file.
void HM_fwrite(void * ptr, int size, int n, FILE * file);
HyperMesh hmlib Function
ptr
A pointer to a block of memory to be written to the file.
size
The size of each item to be written.
n
The number of items to be written.
file
A pointer to an open binary file.
If the write is not successful, the function calls HM_terminate() with an appropriate error message.
None.
