HM_ping_translator()
Tracks the version number of the translator.
void HM_ping_translator(int argc, char *argv[],const char *TVERSION, const char *TIME, const char *DATE)
HyperMesh hmlib Function
argc
Number of arguments passed to the translator main() function.
argv
Arguments passed to the translator main() function.
TVERSION
The version number of the translator.
TIME
The time of the build of the translator.
DATE
The date of the build of the translator.
This command is used so that all translators will report their version information in a consistent manner.
In a translator’s main() function you would use this function according to the following example:
int main(int argc, char *argv[])
  const char *my_version = "1.0";
  HM_ping_translator(argc, argv,my_version,__TIME__,__DATE__);
  /* rest of code */
When "mytrans -version" [i.e., abaqus.exe -version] is entered at the command prompt, theHyperMesh version and the translator version with the time and date of build is displayed.
None.
