HMIN_overWriteEntity()
Will overwrite or not overwrite entities when the option ‘FE overwrite’ is selected during feinput import.
void HMIN_overWriteEntity(HM_entitytype entity_type, int flag);
HyperMesh hminlib Function
entity_type
The entity type to be overwritten or the entity type not to be overwritten.
flag
0 - Not to overwrite an entity when the option FE overwrite is selected.
1 - Overwrite an entity when the option FE overwrite is selected.
The above function can be used if a user does not want to overwrite all of the configurations and types of an entity, or even a particular configuration and type of an entity. The above function supports the following entities:
HM_ENTITYTYPE_GROUPS
HM_ENTITYTYPE_LOADCOLS
HM_ENTITYTYPE_EQUATIONS
HM_ENTITYTYPE_OUTPUTBLOCKS
HM_ENTITYTYPE_ASSEMS
HM_ENTITYTYPE_CONTROLVOLS
HM_ENTITYTYPE_ELEMS
HM_ENTITYTYPE_PROPS
In order to not overwrite a particular element, call the HMIN_overWriteEntity() function with flag = 0, and after writing the element, set flag = 1 so that rest of the elements are overwritten. HMIN_overWriteEntity(HM_ENTITYTYPE_ELEMS, 0);
HMIN_element_writequad4(id, 0, nodes, collectorid);
Write all the attributes belonging to the element quad4
HMIN_overWriteEntity(HM_ENTITYTYPE_ELEMS, 1);
None.
