HMRES_argumentgetlayerdatatypename()
Indicates the data type name and appends, in parentheses, the value of layer at the user-specified index.
char * HMRES_argumentgetlayerdatatypename(int index, int layer);
HyperMesh hmreslib Function
index
The index number of the argument to be checked.
layer
The layer on which the results are stored.
The data type name and value of layer, if it is nonzero, at the specified index.
None.
