HMRES_datatypeclose()
Closes the current data type.
void HMRES_datatypeclose(void);
HyperMesh hmreslib Function
None.
hmlib is a library which contains a set of routines to aid you in writing a C program.
hminlib is a set of routines which allows you to write an external input translator.
hmmodlib is a library of C routines which allows you to perform results translation of more complex data types, such as integration point results or node-on-element results.
Creates a data type.
Determines if the data type already exists.
Opens a data type.
ON THIS PAGE
None.
ON THIS PAGE
