animate framerate
Sets the animation frame rate.
animate framerate <framerate>
Argument
- framerate
- The animation frame rate.
animate framerate 4View new features for HyperWorks Desktop 2022.
Animation controls.
Sets the animation frame.
Linear animation options.
Modal animation options.
Sets the animation mode.
Advance to the next frame.
Return to the previous frame.
Start the animation.
Stop the animation.
Transient animation options.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Animation controls.
animate framerate 4© 2022 Altair Engineering, Inc. All Rights Reserved.
