animate modal
Modal animation options.
animate modal endframe <id>
animate modal increment <increment>
animate modal startframe <id>
Arguments
endframe
The animation end frame.
<id>
Animation end frame ID.
increment
The animation angle increment.
<increment>
Angle increment value.
startframe
The animation start frame.
<id>
Animation start frame ID.
Examples
Set the animation end frame to 7:
animate modal endframe 7
Set the animation angle increment to 1:
animate modal increment 1
Set the animation start frame to 5:
animate modal startframe 5
