hide model
Hides all or parts of a model.
hide model all
hide model <id>
Arguments
- all
- Hides all models.
- <id>
- Hides models based on ID. For example,
(1,2,4)For example, (1-3,5,7).
Examples
hide model allhide model 5View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
hide model all
hide model <id>
(1,2,4)For example, (1-3,5,7).hide model allhide model 5© 2022 Altair Engineering, Inc. All Rights Reserved.
