hide sset
Hides by selection set.
hide sset <label>
hide sset select
Arguments
<label>
Hides selection sets based on labels and label lists (wildcards supported). For example, door, door* and door-left, door-right.
select
Hides sets interactively selected from the modeling window.
select only works in the Unity framework.
Hide the selection set 2D Set:
hide sset "2D Set"
Hide the selection set Set_17:
hide sset Set_17
