result iso clear
Clears the iso plot and returns the model to its original state.
result iso clear <name>
Argument
- <name>
- The name of the iso plot/results to clear. Returns the model to its original state.
result iso clear
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
ClassicCreate and manage iso plots.
Changes the value display.
Clears the iso plot from the graphics window.
Control the iso value displayed on the screen incrementally.
Load and plot the iso data type.
Displays the current iso plot in the modeling window.
ClassicCreate and manage the contour plot.
Set the current simulation.
Makes a subcase current.
ClassicCreate and manage tensor plots.
ClassicCreate and manage vector plots.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result iso clear
