result scalar plot
Upfront Data LoaderPlots the scalar data type.
result scalar plot <name>
Arguments
- <name>
- The name of the plot.
result scalar plot \"Current Contour\"View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Upfront Data LoaderLoad and unload animations.
Upfront Data LoaderCancels all currently loading results.
Upfront Data LoaderCreate and manage iso plots.
Upfront Data LoaderCreate and manage contour plots.
Upfront Data LoaderClears the scalar plot.
Upfront Data LoaderCreates a scalar datatype.
Upfront Data LoaderDeletes the scalar data type.
Turns on/off discrete colors in the contour plot.
Upfront Data LoaderEdits the properties of a result scalar plot.
Clears the scalar plot from the modeling window.
Interpolates the contour colors from the undeformed shape, with a zero value, to the result variable reported from the solver.
Edits the contour plot's legend properties.
Defines the legend's maximum value.
Enables the legend's maximum value.
Enables the legend's minimum value.
Defines the legend's minimum value.
Upfront Data LoaderLoads and plots the scalar data type.
The multiplier for scaling all the result values.
Enter a value that will affect the contour value, contour min/max, and the legend min/max.
Upfront Data LoaderRenames the scalar definition.
Displays the current scalar plot in the modeling window.
Upfront Data LoaderUnloads a scalar data type.
Set the current simulation.
Makes a subcase current.
Upfront Data LoaderCreate and manage tensor plots.
Upfront Data LoaderCreate and manage vector plots.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
Result loading.
result scalar plot \"Current Contour\"© 2022 Altair Engineering, Inc. All Rights Reserved.
