save image
Save the current window or page as an image.
save image page <filename> <name>=<value>
save image window <filename> <name>=<value>
Arguments
<destination>
Destination can be either a <filename> or the string “clipboad” to copy the image to the clipboard. Use the file browser to enter a filename and select a directory to save the file to.
<filename>
<name>=<value>
If the following options aren't displayed, the defaults values will be used as described in config.
<type>=<filetype>
File type options include: JPEG, PNG, BMP, GIF, TIF.
dimension
Define as pixel or percent.
width
The image width.
height
The image height.
quality
For JPEG only. Enter a larger value for JPEG quality for larger files.
page
Save the current page as an image.
window
Save the current window as an image.
Save the active page as a PNG file:
save image page C:\WorkingDirectory\truck.png
Save the active window as a PNG file:
save image window C:\WorkingDirectory\truck1.png
This command only works on the content of the active window.
