save model
Export the page as an H3D file.
save model h3d <filename> <name>=<value>
Arguments
h3d
This option only works on the content of the active window.
<filename>
Use the file browser to enter a filename and select a directory to save the model file to.
<name>=<value>
If the following options aren't displayed, the defaults values will be used as described in config.
  • allmodels
  • animation
  • compressionloss
  • compressoutput
  • entityattributes
  • html
  • includemaskedelements
  • includesets
  • previewimage
  • results
  • viewattributes
Save the active window as an H3D file:
save model h3d C:\WorkingDirectory\truck.h3d
