show component
Shows components in the active model.
show component all
show component marked
show component <range>
show component select
Arguments
all
Show all components.
marked
Show marked components.
<range>
Show components based on IDs. For example, 1-3,8,13-20,25?,3*.
Show components based on labels or lists (wildcards supported). For example, "Rigid Barrier", Bump??, back* and hinge, handle.
select
Shows/hides entities interactively selected from the modeling window.
select only works in the Unity framework.
Examples
Show components 48, 52-55:
show component 48,52-55
Show components by label:
show component "SHELL:       BUMPER"
