show model
Shows all or parts of a model.
show model all
show model <id>
Arguments
- all
- Show all models.
- <id>
- Show models based on IDs. For example,
(1,2,4).
Examples
show model allshow model 5View new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Shows all entities in the active model.
Shows components in the active model.
Shows elements in the active model.
Shows legends.
Shows marked entities.
Shows selection sets.
Shows systems.
Shows a tracking system.
Modify entities in a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
show model all
show model <id>
(1,2,4).show model allshow model 5© 2022 Altair Engineering, Inc. All Rights Reserved.
