sset add
Adds entities to a selection set.
sset add <name> all
sset add <name> component argument
sset add <name> displayed
sset add <name> element argument
sset add <name> marked
sset add <name> range
sset add <name> select
Arguments
<name>
The name of the selection set. For example, Set6. Select the set you want to add entities to. Options include:
all
Add all entities to the set.
component
Add components to the set.
all
Add all components to the set.
displayed
Add displayed components to the set.
marked
Add marked components to the set.
range
Add entities to the set by component ID.
select
Add selections to the set.
displayed
Add displayed entities to the selection set.
element
Add elements to the set.
all
Add all elements to the set.
displayed
Add displayed elements to the set.
marked
Add marked elements to the set.
range
Add entities to the set by element ID.
select
marked
Add marked items to the set.
range
Add entities by ID.
For example, 1-3,8,13-20,25?,3*.
select
Add selection to the set.
Add the component BEAM: DRIVE-SHAFT to Set6:
sset add Set6 component "BEAM: DRIVE-SHAFT"
