sset export
Exports sets to a file.
sset export <file>
Arguments
- <file>
- Displays the file browser. Enter a name and select the directory to export the set to.
sset export C:\Documents\Set_1.txtView new features for HyperWorks Desktop 2022.
Animation controls.
Annotation controls.
Set entity attributes.
Set the entity's color.
Configuration options.
Delete content from the application.
Explode a model or selected components for improved visualization.
Hides all or a subset of entity types in the model.
HyperWorks Desktop commands.
Hotspot finder commands.
Marks entities on the active model.
Open files.
Report commands.
Result loading.
Result loading.
Save session content.
Specify parameters for deformation display.
Section cut.
Shows all or a subset of entity types in the model.
Modify entities in a selection set.
Adds entities to a selection set.
Creates an empty selection set.
Deletes a selection set.
Creates a set with displayed entities.
Imports a set from a file.
Renames a selection set.
Removes entities from a selection set.
Define a coordinate system.
Tracking system commands.
Use tracing commands to trace system, component, and node entities during animation.
View manipulation.
Perform actions on XY plot files.
sset export <file>
sset export C:\Documents\Set_1.txt© 2022 Altair Engineering, Inc. All Rights Reserved.
