hwi GetSessionHandle
Gets a handle to the current session.
hwi GetSessionHandle sessionhandle
HyperWorks Tcl Query
This command retrieves a handle to the current session.
Note: An hwi instance is always available.
sessionhandle
The user-defined name of the session handle that you want to create with this command.
To get a session handle with the name "mySession":
hwi GetSessionHandle mySession
Error
Returns the session handle name if successful; otherwise, an error message.
