Queries whether to apply compression to results during output.
Gets the level of non-lossy compression.
Queries the maximum margin of error allowable during compression.
Queries whether animation data will be exported with the model.
Queries whether attributes will be written out with graphical entities.
Queries whether only visible components will be written.
Queries whether entity IDs will be written with the file.
Queries whether an HTML file will be generated.
Gets whether a preview image should be imbedded in the file.
Gets whether the contour, vector, or tensor data should be written.
Queries whether solids should be written as sets of polygonal faces.
Sets whether to apply compression to results during output.
Sets the level of non-lossy compression.
Sets the maximum margin of error allowed during compression.
Sets whether animation data is exported with the model.
Dictates whether attributes will be written out with graphical entities.
Sets whether only visible components will be written.
Sets whether the IDs should be written out with the file.
Sets whether an HTML file will be generated.
Dictates whether a JPEG preview image is embedded in the file.
Controls writing contour, vector, and tensor data.
Dictates whether solids will be written as 3D elements or 2D faces.
ON THIS PAGE
ON THIS PAGE
