hwIH3DExportOptions SetWriteAnimation
Sets whether animation data is exported with the model.
hwIH3DExportOptions_handle SetWriteAnimation flag
HyperWorks Tcl Modify
If animation data is not written out with the file, the output can only be used as a model file. However, the file will be much smaller in most cases without the additional data.
This command is related to the H3D option on the Publish Session dialog.
flag
True or false.
To disable the writing of animation:
mySessionName GetH3DExportOptionsHandle option_handle
option_handle SetWriteAnimation false
None.
