hwIH3DExportOptions GetWriteAnimation
Queries whether animation data will be exported with the model.
hwIH3DExportOptions_handle GetWriteAnimation
HyperWorks Tcl Query
Returns true or false, depending on whether compression is enabled.
If animation data is not written out with the file, the output can only be used as a model file. However, the file will be much smaller in most cases without the additional data.
To check if animation data will be written:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteAnimation
Error
None.
