hwIAVIExportOptions GetPalette
Gets the palette used when exporting AVI files.
hwIAVIExportOptions_handle GetPalette
HyperWorks Tcl Query
This parameter is used when exporting AVI files from either the video or animation clients during HTML export.
Returns the following:
"fullcolor"
A full color palette is used when exporting AVI files.
"reduced"
A reduced color palette is used when exporting AVI files.
"grayscale"
A grayscale palette is used when exporting AVI files.
To determine the current palette used when exporting AVI files:
mySessionName GetAVIExportOptionsHandle myAviOptions
myAviOptions GetPalette
Error
If an error occurs, this command returns an empty string.
