hwIPage GetActiveWindowExpanded
Indicates whether the active window on the page is expanded or not.
hwIPage_handle GetActiveWindowExpanded
HyperWorks Tcl Query
Returns true if the active window is expanded, false otherwise.
To determine if the active window on page 1 is expanded:
mySessionName GetProjectHandle myProject
myProject GetPageHandle myPage 1
myPage GetActiveWindowExpanded
Error
Success (0) or an error code.
