tblITableEditor GetFilledUpperLeftCell
Returns top left cell name.
tblITableEditor_handle GetFilledUpperLeftCell
HyperWorks Tcl Query
Returns the top left cell name with the column as name which contains a value.
The following cells are filled in a table:
The variable $filledTopLeftCell will be “B5”.
set t [hw::GetT]
set activetableHandle [hwi GetActiveClientHandle ch$t]
set filledTopLeftCell [$activetableHandle GetFilledUpperLeftCell]
