vidIMovie GetFilename
Returns the filename of the movie.
vidIMovie_handle GetFilename
HyperWorks Tcl Query
Returns the name of the movie file.
None.
Returns the number of frames in the movie.
ON THIS PAGE
None.
ON THIS PAGE
