vidIMovie GetNumberOfFrames
Returns the number of frames in the movie.
vidIMovie_handle GetNumberOfFrames
HyperWorks Tcl Query
Returns an integer specifying the number of frames in the loaded movie file.
None.
Returns the filename of the movie.
None.
