Mesh Quality Plots
Mesh Quality Plots module creates the plots for element quality parameters defined in the criteria file.
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Mesh Quality Plots module.
Figure 1. - Name
- The name for the Element Quality Plots module.
- Basic
- Custom Criteria
- Select the check box to enable Load Criteria File selection.
- Load Criteria File
- Select the quality criteria file.
- Once executed, a Plot output for Element Quality Plots is
generated:Coincident Nodes, Coordinate Systems, Free Edges, Element Offsets, Min/Max Length 2/3D and more.
Figure 2. Coordinate Systems
