Model Checker Summary
Model Checker Summary module generates three basic tables outputs along with failed checks tables.
- ERROR Table
- WARNING Table
- INFO Table
- Failed Checks Table
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Model Checker Summary module.
Figure 1. - Name
- The name for the Model Checker Summary module.
- Model Checker Checks
- ERROR Table
- Summary table for entire error check folder
- WARNING Table-
- Summary table for entire warning check folder
- INFO Table
- Summary table for info entire check folder.
- Failed Checks Tables
- Detailed table summary for total failed checks in Model Checker.
- Export Options
- Checks Export Type
- Available export check options are Failed, Passed and All.
- Advanced
- Page Break
- Check to add Page Break at end of the item.
- Once executed, a table output for Model Checker Summary is generated.
Figure 3.
Figure 4.
