Property Summary
The Property Summary module generates summary of entire model properties, by its name, type and ID.
- Property Info with Type and ID
- Properties browser view
- Shell Thickness Summary
- Right-click at the Report or Chapter level and select .
- Below are the properties associated with the Property Summary module.
Figure 1. - Name
- The name for the Property Summary.
- Table of all properties by its Name, Type and ID.
- Replicate Properties browser view
- The currently displayed tabular data in the Properties browser in HM will be copied into a table.
- This option generates the entire model Shell-based property summary based on Shell thickness. It creates a distribution summary as Thickness, Material ID and Property ID.
- Once executed, a table output for Shell Thickness Summary is generated as
follows:Info Model- Text Note. This is created only in Document or HTML reports.
Figure 2. Model Thickness in mm- Image file.
Figure 3. Model Material and Property IDs and plies 0°, 45°, -45°, 90° - Table.
Figure 4. - Once executed, a table output for Property Summary is generated.
Figure 5. Property Info with Type and ID.
