Translators are utilities that are run from the command line of the operating system to convert various types of results
files into a format that the program can read. A table of the translators supplied with the programs appears below. Since
the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Translators
Translators are utilities that are run from the command line of the operating system to convert various types of results files into a format that the program can read. A table of the translators supplied with the programs appears below. Since the program can read HyperMesh binary results files, the entire set of HyperMesh results translators is included.
General Interfacing Aspects
Learn about MotionView interfacing with solvers, MotionView SolverMode, and how to execute solvers.
Interfacing with Abaqus
Overview of how the MotionView applications interface with the Abaqus solver.
Interfacing with ADAMS
Overview of how the MotionView applications interface with the ADAMS solver.
