FE geometry is topology on top of mesh, meaning CAD and mesh exist as a single entity. The purpose of FE geometry
is to add vertices, edges, surfaces, and solids on FE models which have no CAD geometry.
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running
it through either component or element selection.
Define Nodal Equivalence
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
