Seatbelt Auto-Extraction
Auto-extraction from the FE model allows for a quick recovery of the seatbelt system without having to recreate the seatbelt.
View new features for HyperWorks 2022.
Position a dummy model using the Dummy Browser.
Create and articulate a kinematic mechanism based on FE mesh using the Mechanism Browser.
Use the Seatbelt Browser to create a complete seatbelt system.
Create a complete seatbelt system, with meshed fabric components and solver-related seatbelt features.
Create a seatbelt mesh.
Apply tension to a seatbelt for testing using the tensioning option.
Create solver seatbelt features using Control Points.
Create solver cross-sections on the seatbelt mesh.
Use the Link Dummy Mechanism to update dummy and seat motion.
In this tutorial you will create a seatbelt system and all related solver seatbelt entities.
Use the Barrier Positioner tool to automatically get the impact barrier into position, based on the selected crash regulation.
The Pedestrian Impact tool automates the vehicle marking, impactors positioning and the export of solver decks with minimal input, therefore reducing the full process lead time.
Generates a deck for the simulation of the head impact on an instrument panel.
Use the Safety ribbon to access crash and safety post-processing tools.
Explore the GeoD user interface.
