Contact Surfaces
Contact surface entities define and store contact definitions typically used in contact analysis.
Contact surfaces are defined using elements (1D/2D/3D) and their respective facecodes. A contact surface is displayed as an arrow on the selected element faces in the modeling window. The direction of the arrow is along the element normal that defines the contact surface.
ANSYS Cards
| Card | Description |
| CONTACT174 (updated to version18 and above) |
EXODUS Cards
| SideSets | Provides a second means of applying loads and boundary conditions to the model. |
LS-DYNA Cards
| *SET_SEGMENT | Definition segments on element faces. |
Nastran Cards
| ELIST | Defines a list of CQUAD4 and CTRIA3 structural elements for virtual fluid mass. |
OptiStruct Cards
| ELIST | Specifies damp shell elements for a fluid volume. ELIST entries are referenced by the MFLUID entry. |
| SURF | Defines a face of a 2D or 3D element as part of a surface. |
Permas Cards
| $SURFACE | Surface definition. Note: The name of the contact surface is getting exported
to the SFSET parameter. On import, the contact surface will
be named after the SFSET parameter.
Known limitations:
| $SURFACE_GEO | Surface defined by interpolation of nodes. |
Radioss Cards
| /LINE/SEG | Definition of a line. Note: Block Format Keyword
| /SURF/SEG | Defines a face of a 2D or 3D element as part of a
surface. Note: Block Format Keyword
Samcef Cards
| .SEL FACE | Defines a set of faces of 3D elements |
