Remove Logos
Use the Defeature: Logos tool to find and remove logos.
View new features for HyperWorks 2022.
Explore the tools used to create geometry.
Explore the tools used to edit geometry.
Clean up problematic areas on geometry.
Use the Defeature tool to automatically find, review, and defeature holes and other non-essential features.
Use the Defeature: Cuts tool to extend surface edges and remove cutouts.
Use the Defeature: Small Features tool to find and remove/fix small solids and surfaces.
Use the Defeature: Fillets tool to find and remove both round (convex) and fillet (concave) surfaces.
Use the Defeature: Holes tool to remove solid holes in the model.
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Use the Preserve Edges tool to ensure that specific component edges and feature lines do not accidentally get discarded during auto cleanup or batch meshing.
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology.
Find intersections and penetrations between geometric surfaces and solids.
Explore the GeoD user interface.
to define settings for logo
detection.
