Split with Nodes
Use the Split: Nodes tool to split surfaces using ordered (node list/path) and non-ordered nodes selections.
Note: This tool is supported for FE geometry.
From the Geometry ribbon, click the Split > Nodes tool.
Figure 1. - Optional:
Select surfaces to split.
Note: Target surface selection on the guide bar is optional if only two nodes are selected. If selecting a node list or node path with two or more nodes, you should select the target surface on the guide bar before selecting nodes.
- Activate the Nodes selector on the guide bar.
Make your node selection according to the following table.
Option Description Nodes Left-click on 2 nodes. Node List Left-click on individual nodes to create the desired path. Node Path - Click
on the guide bar to launch the advance selection menu
and select by path. - Left-click to create the path's start and end points. A preview of the path will be displayed.
- Click
- Click Split on the guide bar.
