Release Degrees of Freedom
Use the 1D Mesh: Pins tool to edit and release degrees of freedom.
You can select a single element at a time and review or edit the released degrees of freedom at node A and node B.
View new features for HyperWorks 2022.
Edit the Parameter and Criteria files and define mesh controls using the Mesh Controls Browser.
1D mesh that allows accurate testing of connectors, such as bolts, and similar rod-like or bar-like objects that can be modeled as a simple line for FEA purposes.
Supported 1D elements.
Use the Beam Sections tool to create and edit standard beam sections, cross beam sections, and HyperBeam sketches.
Create 1D mesh, align, orient, and offset elements, and release degrees of freedom.
Use the 1D Mesh: Create tool to create 1D elements on lines or nodes.
Use the 1D Mesh: Align tool to reorder the N1 to N2 sequence of 1D element nodes.
Use the 1D Mesh: Orient tool to define bar2 orientation vectors or orientation nodes.
Use the 1D Mesh: Offset tool to manually set offsets or adjust beams on plates.
These tools enable the creation of 1D elements from surface lines, organizing them into components. They also offset/orient these elements based on the attached shell elements and calculating properties of these 1D elements from 3D solid or shell FE element sections.
Use the 1D Mesh: Review tool to plot area moments of inertia and stiffness.
Use the Section Property tool to update properties assigned to bar2 or rod elements (target) using a cross section on various entities as the source.
A surface mesh or "shell mesh" represents model parts that are relatively two-dimensional, such as sheet metal or a hollow plastic cowl or case.
Volume mesh or "solid meshing" uses three-dimensional elements to represent fully 3D objects, such as solid parts or sheets of material that have enough thickness and surface variety that solid meshing makes more sense than 2D shell meshing.
Explore the GeoD user interface.
