Register Morph Volumes
Use the Morph Volumes: Register tool to review and edit the contents of morph volumes. Only registered contents will morph when morphing morph volumes. Entities that can be registered to morph volumes are nodes and connectors.
View new features for HyperWorks 2022.
Morph constraint entities restrict the movements of nodes or force compliance with dimensional requirements during morphing. These constraints are always valid for all available morphing approaches.
Use the Free tool to morph mesh by moving nodes, faces, edges, and shapes or by mapping to geometry.
Use the Proximity tool to morph mesh using a simple distance or perturbation value around selected nodes, faces, edges, or shapes.
Morph volume entities are highly deformable six-sided prisms which surround a portion of the FE mesh, and can be used to manipulate a mesh by manipulating the shape of the morph volume.
Use the Morph Volumes: Enclose tool to create morph volumes with rectangular or circular shapes. Enclosed mesh and connectors are automatically registered to the enclosing volumes by default.
Use the Morph Volumes: Move tool to morph or adjust morph volumes by moving vertices/handles, edges, and faces with graphical manipulators.
Use the Morph Volumes: Split/Combine tool to split morph volumes using a single or multiple locations along an edge, combine adjacent morph volumes along shared faces, join pairs of separate morph volumes, or equivalence any number of morph volume faces using a search distance.
Shapes are collections of perturbations from the initial configuration of the FE mesh before the morph.
Domain entities divide the model into different domains during morphing.
Handle entities control the shape of domains during morphing.
Symmetry entities define planes of symmetry within a model so that morphs can be applied in a symmetric fashion.
Undo all morphs and return to the original state of the model.
Explore the GeoD user interface.
Nodes can be manually registered to individual selected volumes, while connectors are always registered to volumes physically enclosing them (automatic).
