Find Equivalent Joints
Use the Equivalence tool to consolidate overlapping joints within a given tolerance.
                        ![]() Figure 2. . Original model containing overlapping joints  |
                        ![]() Figure 3. . Post equivalence the overlapping joints are consolidated  |
                        ![]() Figure 4. . Original model containing three joints located in the center of the members. If “Allow member destruction” is active, the central members are removed.  |
                        ![]() Figure 5. . Post equivalence the joints are consolidated, and the two members are removed  |
 or
 to
                    review each instance.
