PAM-CRASH 2G Conversion
PAM-CRASH 2G to Radioss Conversion Mapping
Elements
表 1. Supported Element Mappings
PAM-CRASH 2G Radioss
BAR TRUSS
BEAM BEAM
SPRING SPRING
SPRBM SPRING+PROP/SPR_BEAM (TYPE 13)
MEMBR SH3N, SHELL
SHELL SH3N, SHELL
SOLID BRICK
TETRA44 TETRA44
MASS ADMAS
PLINK SPRING+INTER/TYPE2
KJOIN SPRING+PROP/KJOINT(TYPE33)
Boundary Conditions
表 2. Supported Boundary Condition Mappings
INIVEL INIVEL
BOUNC BCS
CONLO CLOAD
Systems
表 3. Supported System Mappings
FRAME FRAME
Materials
表 4. Supported Material Mappings
MAT_1D TYPE 201 M1_ELASTIC
MAT_1D TYPE 220 /PROP/SPRING
MAT_1D TYPE 223 /PROP/SPR_BEAM
MAT_2D TYPE 100 M0_VOID
MAT_2D TYPE 101 M1_ELASTIC
MAT_2D TYPE 102 M36_PLAS_TAB
MAT_2D TYPE 103 M36_PLAS_TAB, M44_, COWPER
  M2_PLAS_JOHNS
Curves
表 5. Supported Curve Mappings
FUNCT FUNCT
Control Cards
表 6. Supported Control Card Mappings
TITLE TITLE
OCTRL/
DSYOUPUT /ANIM/DT
THPOUTPUT /TFILE
Components
表 7. Supported Component Mappings
PART PART
Contact Interfaces
表 8. Supported Contact Interface Mappings
CNTAC36 INTER/TYPE7
CNTCT33 TYPE7
Properties
表 9. Supported Property Mappings
MPART(Type=Solid) /PROP/SOLID
MPART(Type=Shell) /PROP/SHELL
Rigid Walls
表 10. Supported Rigid Wall Mappings
RWALL RWALL
Time History
表 11. Supported Time History Mappings
THELE TH/SHEL, SH3N, SPRING, BRIC
THNODE TH/NODE
THLOC TH/FRAME/ACCELEROMETER
Sections
表 12. Supported Section Mappings
SECFO SECT
Sets
表 13. Supported Set Mappings
GROUP(components) SURF/PART/EXT
Groups
表 14. Supported Group Mappings
GROUP GRNOD
Airbags
表 15. Supported Airbag Mappings
BAGIN MONVOL
