Circle
Model ElementThe Circle element allows you to generate a circle graphic defined by a center marker and a reference marker or a radius.
Class Name
Circle
Attribute Summary
| Name | Property | Modifiable by command? | Designable? |
| cm | Reference(Marker) | No | Yes |
| radius | Double() | Yes | |
| seg | Int() | ||
| rm | Reference(Marker) | Yes | |
| color | String() | ||
| hidden | Bool() | No |
Usage
Circle(cm=Marker(), radius=100, seg=20, rm=Marker())
- cm
- Reference(Marker)
- radius
- Double()
- rm
- Reference(Marker)
- seg
- Int()
- color
- String()
- hidden
- Boolean
Define circle geometry
Circle (cm=marker1,rm=marker2, seg=20)Comments
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
