Model ElementThe ParamCurve element allows you to represent a curve defined in the
model as a Curve element. The graphic is defined by a number of straight
line segments connecting vertices on the curve defined by Curve
reference.
Attribute Summary
| Name |
Property |
Modifiable by
command? |
Designable? |
| curve |
Reference (Curve) |
No |
Yes |
| rm |
Reference (Marker) |
Yes |
| seg |
Int
| material_inside |
Bool
| color |
String() |
| hidden |
Bool() |
No |
Usage
curve = ParamCurve(rm=Marker(), curve=Curve(), seg=20)
Attributes
- curve
- Reference (Curve)
- The curve entity represented by this graphic object. This attribute is
mandatory.
- rm
- Reference (Marker)
- The coordinate system with respect to which the curve points are
defined.
- seq
- Int ()
- Specifies the number of segments used to represents the Curve.
- material_inside
- Bool ()
- Specifies if the graphic has material inside or outside.
material_inside is a Boolean flag
(True/False).
- True means the geometry is solid. In other words, it is
filled with material and its exterior is devoid of material. Consequently,
the surface normals of the geometry point outward.
- False means the converse: The exterior of the geometry is
filled with material and the interior is devoid of material. In this case,
the surface normals of the geometry point inward.
- color
- String()
- The color of the graphic for H3D animation. Specified as RGB (Red : Green :
Blue).
- hidden
- Boolean
- Specifies weather the graphics is being written to the H3D file or not.
- True implies that the graphic is hidden and is not
written to the H3D file.
- False implies that the graphic is not hidden and is
- This attribute is optional. When not specified, it defaults to
False.
- See Properties
for an explanation about what properties are, why they are used, and how you can
extend these.
