BodyResult
Results ElementBodyResult is an object that contains all the results associated with single body from a simulation.
Class Name
BodyResult
| Entity | Component Name |
| Rigid Body | (0-6): X, Y, Z, E0, E1, E2, E3 |
| Point Mass | (0-2): X, Y, Z |
| Flex_Body | (0-6): X, Y, Z, E0, E1, E2, E3 (7-12): X_dot, Y_dot, Z_dot, ωx, ωy, ωz (13-18): X_dotdot, Y_dotdot, Z_dotdot, ωx_dot, ωy_dot, ωz_dot (19-18+Nmodes): Modal participation factors (19+Nmodes): Strain energy |
- At T=0, for each Body in the model (Rigid, PointMass and Flex_Body)
- A BodyResults object is created
- The object is stored in the SimulationResults container object
- At each output time (including T=0):
- for each Body in the model (Rigid, PointMass and Flex_Body)
- The body results are appended to the BodyResults object
- Thus at the end of the simulation, the SimulationResults object is fully "populated"
Usage
See SimulationResult
Demonstrate the use of BodyResult to create plots from MotionSolve results.
- Perform a dynamic simulation from 0 to 2 seconds with 200 output steps.
- Extract the time history for the translational X component of the displacement of Body1.
- Plot the X time history in matplotlib.
# Perform a simulation
run = M.simulate(type="DYNAMICS", end=2, steps=200, returnResults=True)
# Get the force request data from the run object
req = run.getObject (model.body1)
# Extract the time and X signals
times = req.getComponent ("times")
FZ = req.getComponent ("X")
# Plot the signal
import matplotlib.pyplot as plt
plt.plot (times, FZ)
plt.title ("Body1-X vs. Time")
plt.xlabel("Time")
plt.ylabel ("Displacement [m]")
plt.grid (True)
plt.show()
- See Properties for an explanation about what properties are, why they are used, and how you can extend these.
- The SimulationResults may be queried to get access to the time histories of its various components. See the examples above.
