/GRSPRI/GRSPRI
Block Format Keyword Describes the spring groups which are selected from other spring groups.
| /GRSPRI/GRSPRI/grspring_ID/unit_ID | |||||||||
| grspring_title | |||||||||
| item_ID1 | item_ID2 | item_ID3 | item_ID4 | item_ID5 | item_ID6 | item_ID7 | item_ID8 | item_ID9 | item_ID10 |
| grspring_ID | Spring group
| unit_ID | Unit Identifier (Integer, maximum 10 digits) |
| grspring_title | Spring group
| item_ID1, item_ID2,... item_IDn | List of spring group
identifiers (Integer) |
- If item_ID is a negative number, the item number is deleted from the group.
