Materials
Material properties are used for the beam elements in constructing the leaves.
Material Properties
- Young’s Modulus
- Defines the Young’s Modulus value for beam material.
- Shear Modulus
- Defines the shear modulus value for beam material.
- Density
- Defines the beam material density.
- Beam Damping Ratio
- Defines the beam damping ratio.
Material Properties for Leaf Property File (*lpf)
In the Material Properties block of leaf property file, the attribute, type, and valid value that has to be entered in TiemOrbit file format are detailed in the following table. This table also provides information about the mandatory requirements for attributes.$------------------------------------------MATERIAL_PROPERTIES
[MATERIAL_PROPERTIES]
(STEEL)
SHEARMODULUS = 80000.0
YOUNGMODULUS = 205000.0
DENSITY – 7.8E-06
BEAMDAMPINGRATIO = 0.001
- Block Name = ‘MATERIAL_PROPERTIES’ (Required)
- Sub-block Name = ‘steel’ (Default)
Attributes Type Valid Value Required youngsModulus Real Units should be MPa Yes shearModulus Real Units should be MPa Yes Density Real Units should be Kg/mm3 Yes beamDampingRatio Real - Yes
